[Pro] vertical, horizontal alignment java script
I’m very close to buying Pro in replacement of an ever frustrating iWeb but one of the major things I need is to vertically align my sites to the browser window using java script. Is this as easy as dropping in the script or do I have to jump through hoops as in iWeb?
On Aug 9, 2010, at 3:36 PM, Brian Rolfe wrote:
I need to vertically align my sites to the browser window using java
script.
I’m pretty sure there’s an Action (Vertical Align?) that does this.
This can also be accomplished with only CSS. Not sure which approach
the Action uses.
thanks, found it, will look have to see if it works the way I need
