[Pro] Very SLOW!
Sites that ran normally under Freeway versions 3.xxx are now running incredibly slow under version 5.3.2 Why is this? (yes, I have repaired permissions)
Do you mean the document, in Freeway, or the site on your Web server?
The document in Freeway. Once it is up on the net it runs normally.
Is this a document you have opened in 5 and then saved? There’s a translation process that has to happen to upgrade a document from 3 to 5, and that might take some time. But after it’s been saved? (Mind you, I haven’t tried this particular leap myself, having gone through 4 as a middle step.) You might want to send the document to Softpress support for dissection.
Thanks, Walter. I will!
