[Pro] Visible on scrolling
Hi, how is this done:
(sample site right hand lower corner)
Scroll down a little bit and “back to top” appears.
Thanks, Lode
http://www.knack.be/nieuws/
You can certainly do this with javascript
This is something I built a while ago but it uses jQuery so not ideal if you are using FW’s native actions on the same page.
http://www.deltadesign.co/fw_examples/jQuery/scroll-appear.html
You can also use CSS and there is an animation library that Tim uses in some of his stuff at freewaystyle.com implemented with his AnimationFX action - have a look at https://dl.dropboxusercontent.com/u/795566/freewaystyle/demos/Monarch/index.html
More at Animate.css | A cross-browser library of CSS animations.
Many ways to skin this particular cat.
