Okay, in order not to be a total ass …
Yes, the Caxton action in combination with fontsquirrel.com could just work out just fine, even I couldn’t make font families work with it. But IE shows the used fonts just fine.
Hi Carla,
What version of the Action are you using? I updated the Action with a minor fix last week and have just uploaded it to the site. See if version 1.4 helps; http://www.freewayactions.com/product.php?id=034
On 27 Feb 2013, at 18:56, Carla wrote:
I used Web Font action on a website but the whole thing fell apart on Internet Explorer
I just looked at the Webfont action I had and the date is Feb 5, 2013
Is this new one I just downloaded a newer version?
I can not find the version #
Thx
Hi Carla,
I uploaded a version tonight so the Action file should have todays modification date. If you open the Actions palette in freeway the version number for the Action is displayed in the lower right hand corner of the palette.
