Remember, each time you publish, the contents of your local Resources folder (and in fact, the entire contents of your local Site Folder) are replaced by Freeway. Any files you add or edit to the folder on your Mac will be studiously ignored by Freeway when uploading to the server, and potentially overwritten by Freeway at the next publish. To really fix this issue, you must figure out how you were intending the fonts to be uploaded to the server. If you were using an Action like Caxton to upload the files automatically, then you need to potentially figure out how the Action lost track of the font file so this issue doesn’t repeat.
It is a frequent issue with files managed by Actions that Freeway will lose track of the original file without throwing an error. You may need to use the (Control key down) File / Publish Everything… hidden menu command, or the Edit / Resources (Resample All) dialog button to force it to retain control of the file. In extreme cases, you may need to remove the Action from your document (all pages), publish once without the Action, then re-apply it and re-configure it on all pages to re-attach the file the “right” way.
Manually mucking with the Site Folder is a short-term solution at best. Once Freeway figures out that the file is missing, or it sees the one you added, it may re-make all the links to the font as ClaireHandRegular-1.ttf (to avoid stepping on a file it doesn’t recognize as its own). When that happens, your file on the server will no longer be referenced by any html file, and you’ll be back where you started.
On Feb 22, 2014, at 11:02 AM, Mark Lawrence wrote:
Hi Walter,
Thank you for your reply.
Seeing that you said it was a missing resource, I thought I’d just copy and paste the font into the resource folder. And for some reason that did the trick.
So working ok now, but thank you for your help.
Enjoy your day
Mark
