Hi Billy you may want to look at the other bits of javascript you have running on that page. Even though the webyep bit is the element thats being effected. its most likely being caused by some thing else. Disable all the other libraries and then try again. If readable them one at a time you can narrow down the problem… I would start at all off and makes sure webyep loop functions correctly then say check pie turn that on and so on
