Hi, I am interested to know how to setup Webyep items within Freeway which allow for flexible heights. The freeway page would in turn also need to expand downwards to allow for extra content. For instance, a Webyep text box can be edited by a client, however, should they add more text than can fit into the box, it will not display. If the Webyep item only becomes expandable, then how does the freeway page follow in its expansion?
Is there a tutorial or similar available to achieve this?
Hi Matt, if you do a hunt for Inline layouts (or Box Model - as it used to be called on here before we were corrected), then that should head you to a good starting point.
For everything to expand, you really need to construct an Inline layout (box inserted within another box and so forth) otherwise you will get overlaps and all sorts of horrible things happening. The relative Page Layout action may be able to help if you’re unsure, but I’ve never used it so can’t say for certain.
Hope that helps (a bit)
