I have a site with many images on it to be updated by Webyep. How do I set it up so that there is a standard width and the height adjusts to fit? I did specify Fixed width and auto resize the height in the extended area for a webyep image but it does not seem to work.
Hi Bobby
If you want the size to be fixed then you wont want a height to be auto because that means the height will automatically adjust in proportion to whatever width you have set within Freeway
In the manual I have gone into some detail on what that part of the action does but if it doesn’t make sense could you describe what you actually want to visually see and how you want webyep to handle a portrait and a landscape uploaded image
