Dave that would be a nice alternate. Can you show mw how you did it or send me an example that I could scan through.
Much appreciated.
Billy
Much appreciated.
Billy
The link is in one of my posts from the 9th
Hey Dave,
Will Tool Tip use the alt text in a Web Yep image element for it’s content?
Billy
Struggling here Tool Tip. when I am adding the image tags does this look correct? See below Also not sure what the class is. Is it “tool” or “TipEx” ?
var uniTipTag = “a,img1,img2,ing3”; //Which tag do you want to uniTip-ize? Keep it lowercase. No spaces around commas.//
var uniTipClass = “tool”;
Hey Dave,
Finally figured out the reason the tool tip was not working was because the folder permissions were incorrect. Needed to be 755.
Could you tell me where do you set the max-width/Height of the tip itself. Also can I state leading/line-height?
The background images are not showing either.
My site Url is smartytest.com/Greek/
Here is what I’m seeing in the Css file for the path
/images/TipPoint.png.
Billy
What page should I be looking at?
Yes, line-height
#unitip {
position: absolute;
z-index: 1000;
top: -1000px;
color: #8CCDFF !important;
font: normal normal 1em/12px Verdana, Arial, Helvetica, sans-serif;
line-height: 19px !important;
display: none;
smartytest.com/Greek/workpage.php
I got the line height, I just can’t get the the text width to be a little longer maybe 100px
The major thing is the background images are not showing up.
Billy
I am only seeing Capty on that page
So Sorry it’s smartytest.com/Greek/workpage2.php
You appear to have 2 references to the css file
<link href="http://www.smartytest.com/Greek/unitip/css/unitip.css" rel="stylesheet" type="text/css" />
<link rel="stylesheet" type="text/css" href="http://www.smartytest.com/Greek/unitip/css/unitip.css" />
Just use the second one
Then in the unitip.css file change the relative path from
url(/images/TipPoint.png) no-repeat;
to
url(http://www.smartytest.com/Greek/unitip/images/TipPoint.png) no-repeat;
In each of the 3 instances
You are also trying to load unitip.js twice
<script type="text/javascript" src="unitip.js"></script>
<script type="text/javascript" src="http://www.smartytest.com/Greek/unitip/js/unitip.js"></script>
Take out the first one.
And also you are loading jQuery after you load unitip.js
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.3.2/jquery.min.js"></script>
jQuery should come first. ie
Sort that lot then we will look again.
Ok so I got the images now but I did something to cause the the css to show on the page.
The Read me doc in the download is slightly different than the tutorial webpage, I’ have go myself very confused.
Billy
Ok, I got it fixed. I think it is right. Also how do I edit the tip width?
Billy
