billyk
August 1, 2014, 7:37pm
1
Struggling to get my Web Yep menu to float or align center of my page. I’m working in the new Freeway Responsive so I’m thinking there is something up with my floats and clears.
Ugh!
Billy
http://smartytest.com/Greek/ourwork.php
hi billy try this
you need a container which is 100% wide so that is you white strip.
then click inside so you see a flashing cursor and insert a normal html box
resize it so its the same hight as the white strip
then use these setting
float:none and
margin:auto
then click on the box and use extended and put in a new style… min-width:50px
apply the webyep menu action
I think that will then centre your menu
all the best max
billyk
August 4, 2014, 9:19pm
3
Hey Max,
Thanks. I tried this but had no luck. Maybe I’m not setting the divs up correctly. Could you send me and example.
