The bottom “boxes” are single list items in 3 separate html boxes, while
the top “boxes” are a single 3-item list. Both rows are styled with CSS to
look like boxes, likely with an action.
Your problem is a thing called The Box Model, which is how browsers
determine the size of an html item box. Internet Explorer has a history of
inconsistencies when it comes to correctly rendering the box model. In your
top row, IE has only one div to screw up, while in the second row there are
three container divs to render incorrectly – not to mention the divs inside
them like the ones for the arrows – which only compound the problem.
You should simplify. However you made the top row, make the second in the
same way. I would use advanced CSS techniques within Freeway Pro, but that
is just me.
Best wishes,
On Fri, Aug 3, 2012 at 3:36 AM, Mark Lawrence email@hiddenwrote:
Hi Dave,
Thanks for your post.
This is my current site: www.alternative-angles.com/preview
Just to quickly explain, I played with it last night and the first three
sets of blue oblongs (smaller ones) seemed to work on Internet Explorer. So
I might well have fixed it.
But the bottom set still came up as different sizes in Internet Explorer.
Also, the Search text box on the top right just won’t line up. To get it
the size I want in Safari I have to make it twice the size I want it in
Freeway to get it the right size when I publish. But as sod’s law would
have it, when I view it in Internet explorer it’s well out of alignment.
Can you tell me what I’m doing wrong?
Many many thanks
Mark
