Okay, let me throw some stuff out there - see if any of it sticks.
There are a few contributing factors, but I think you’ll find the problem
manifests somewhere in the menu - maybe the submenu for the last menu item
(Resources). Since it pops out to the right, it reserves that space - maybe?
I’m not sure what the solution is, just that when I delete the menu (or
remove the float) it fits the page.
You’ve a fixed-width of 960px - which is wider than the 768px width of
iPads in portrait orientation, so it can only scale as a whole page. So
max-width to describe the #PageDiv page width doesn’t really make sense.
Also, device-width in the Mobile setup I think might work better.
Also, Kelly - why are you using 4px height divs in the #section-slider ?
Why not trash those extra elements and style the top and bottom border of
#section-slider instead?
Best of luck working this out.
On Mon, Sep 29, 2014 at 2:53 PM, RavenManiac email@hidden wrote:
I have this website set to center on a page, but for some reason when it’s
viewed on an iPhone or iPad it tends to left justify, especially when
switching either device to landscape viewing.
I’ve racked my brain trying to figure this out, but I can’t find the
solution. Any help is very much appreciated.
http://www.williamsburgmemorialpark.com
