[Pro] WebYep 3.3 error message "me has no properties"
Since I installed the latest WebYep action suite I get the following error message while generating the freeway files
Action: WebYep: 4-Richtext
Any ideas how to solve this problem?
Thanks for your support
Stefan
some additional information
The Richtext element is part of the following structure
  • LoopStart
    RichText
  • LoopEnd
and integrated in inline box model
Sample site (before installing webyep 3.3): genussguerilla: Error Page
Hi Stefan – I’ve had this error message when I’ve inserted the Rich Text action into an existing box element, using the cursor to give an inline insertion.
If memory serves me, I had to create a new html box element to the size required and then apply the Rich Text action to this, using the same name as I’d used previously so as to maintain the data.
Hi Stefan
I would need to see how you have constructed the page but from your description it should work.
If you could send me the freeway page in question and I shall have a look
All the best max
Hello Max,
should I sent you the complete freeway project?
In case you need only the page causing the problem I haven’t seen yet the option how to export a single page.
Stefan
Deleted WebYep actions and inserted them afterwards again - problem was fixed afterwards
Stefan
