Hi I have 2 accordions on a page that work fine except in internet explorer any ideas anyone? Page is at Thai Namoon dot com /therapies.php the code is from webyeps example page I suspect my inexpert tinkering with it has caused the fault.
HiSimon you know you have jQuery and scriptaculous running
have you set jQuery to no conflict?
Alternatively why don’t you use a scripty accordion instead then you wont have to load two libraries
max
Cheers Max, I guess this is from the webyep gallery page? As far as I know jQuery is set to no conflict ie WY.$ = jQuery.noConflict(true). I’ll give scripty a look, does anyone know if i can set the accordion up so that even after the initial open it can all be shut again?
I’m going nowhere fast on this I’ve tried applying the scripty accordion action to an html box containing the loop with a short text and a rich text styled as .h2 and .p respectively, that doesn’t seem to work. I’ve tried tinkering with the hand coded examples which is how I got the jQuery version working and although I can get the webYep loop inside what I expect to be the accordion it just sits there open like js is off. I get a bunch of js errors in the debug but I’m no where near experienced enough to know what to do with them…help!
Open this page in Safari’s Developer Tools and look at the long list of missing JavaScript resources (click on the Console button, looks like a little speech bubble from the comics). It looks like you’ve tried several different things, and left parts of them behind in your code.
