I’m getting a problem where WebYep inserts an unwabted character before a pound sign when used inside a short or a long text box - I’ve not tried a Rich Text box yet.
Both the Freeway document and the WebYep config file are set to utf-8.
£134,950
The extra character has been inserted into the code before the pound sign. I can only assume this is the WebYep engine inserting this rather than something the action instigates, but thought I’d check first.
Hi Ian you should be bale to use the £ sign as normal
I did a quick check on my site just to make sure it didn’t duplicate your problem and unfortunately I cant
Although the Freeway document set-up preference creates all new pages with the utf-8 character set, the pages causing the problem were old ones still on ISO-8859-1. As soon as I checked all the source code for the wayward pages I realised.
Simple matter of changing the character set of a few pages to utf-8.
