Hi guys,
I hope someone can help me with a problem
See link below, i installed webyep
Everything works accept uploading a photo
The error I receive is:
Error during file transmission
Hi Erik,
I would imagine that your webyep-system > data folder is not writable. Check the permission settings on the directory using an FTP application like Fetch or CyberDuck and make sure that it is writable by the system.
On 23 Jul 2012, at 19:45, Erik wrote:
Hi guys,
I checked my permission for the data folder, but they are OK (777), I’ve tried different browers, reinstall the system, update WebYep but still the same error.
The WebYep status page seems to be OK (as far as I can see)
Hi erik thanks for the artwork
I will have a look at how you have constructed the artwork and what else may be causing the problem plus I can check it locally on my server cheers max
Can it be a browser problem?
Tested it earlier on my Mac in Firefox (latest version) and Safari.
On other websites of mine it works without any problem?
Hi Erik
sorry for the delay
Well I have tested your artwork locally with a new fresh version of webyep and the images upload correctly.
I have emailed you directly about what we can test next
speak soon max
