I have made a quick test page Gallery using Webyep.
I wish to adopt the lightbox effect & have placed the folder into the webyep-system/program/opt folder on the server. From that point on, WebYep will make use of Lightbox. - According to the manual…
But as my link shows it doesn’t work?!!
Does anyone know why?
Is it becasue This function is only available when using WebYep system 1.2.4 as the manual says, or is this out dated now & compatible with the latest version of Webyep? Im currently running 3.1
Your an absoloute Star!!! It fixed it, I think KEY changes in the way WP & FW work such as this should be updated within the manual as soon as they occour!
It would save a lot of time & hassel for me & subsequent users.
Nothing against Max as he does a sterling job, & is currently working on the next release… but something so simple could have saved me a lot of time.
Unless a jQuery element is set to use the noConflict() mode, you can pretty much count on it nuking anything Prototype on the same page. Further, unless your users are all on land-line Ethernet or cable modems, you can count on the page becoming really heavy in terms of file size.
On Sep 17, 2012, at 11:12 AM, Mr worm wrote:
Hi Thomas,
Will this jquery script clash with carousels on the page or actions like news cycle?
I’ve been helping him off-line, and he has much larger issues here – there are three different invocations of Prototype and Scriptaculous in the head of his page, two of the current version and one of the older version. It’s a real mess at the moment. Adding jQuery on top of that is going to make somebody’s browser explode!
On Sep 17, 2012, at 1:47 PM, Thomas Kimmich wrote:
… all correct.
But if you will be political incorrect and give this anyway a go try:
