[Pro] WebYep Menu Styler problem
I don’t seem to be able to get the WebYep css menu styler to work, it’s having no effect at all.
I’ve used the styler on static in-line constructed sites before without any issue but this site is built with Backdraft 2.0 - I don’t know if there is some compatibility issue with BD & WebYep?
Steve
http://94.136.40.103/~cheaper-school-prospectus.co.uk/wgsp/goodpractice.php
Hi steve thats
there needs to be a div around the menu called MyMenu.
just add a normal html item as an inline in place of the webyep menu , then apply the webyep menu to that and make sure its called MyMenu within the inspector palette
speak soon max
Thanks Max, it works a treat now - I was beginning to pull my hair out!
I did put on a seperate thread another webyep question that I wondered if you would be able to help me out on: [Pro] WY rich text vertical align | FreewayTalk | FreewayTalk
I can’t get the vert alignment of the rich text item to be the same as other items??
Cheers for the help!
Steve
Hi Steve that will most probably be because the rich-text adds a paragraph tag around any text
Which editor are you using … CkEditor or TinyMCE?
speak soon max
Using tinyMCE - on the other pages with the same issue I’ve just added a 15px padding to the top of the non-rich text items to bring them in line; it works but I guess it’s not ideal.
Steve
ok you need to create a special style sheet for Tinymce and then add the location of that style sheet within the wy-richtext action palette
In that style sheet you need to add these styles
h1:first-child, h2:first-child, h3:first-child, h4:first-child, h5:first-child, h6:first-child, p:first-child { margin-top:0px }
This should then remove the initial space above the first item within the richtext area
max
