If I use WebYep in my Freeway pages and I make changes to the site design after the client has made content changes to it using WebYep does Freeway wipe out those content changes?
Mike
Hi Mike
as long as you don’t delete the WebYep items from the Freeway document or rename them within the WebYep palette, then you can move things about add more design elements create new pages and even change the complete visual look.
The only other thing that would cause a problem is if your page where your WebYep content was on, was to be renamed to something completely different that
for example:
mypage.php was renamed to maxpage.php
That too would course WebYep to lose its reference to where the content is supposed to go.
I hope that helps
Kind Regards Max
Thanks Max, that’s kinda what I figured, but wanted to make sure.
