I have this carosel I am trying to make, if you click on each box it does nothing then almost does one transition. I have no idea what is wrong. These are not all my finished slides, I just wanted to get it working before I worked on the slides. http://sunshineambassadors-dance.org/carosel.html#NL1
There’s a link on this page to download a Freeway file, but it’s not
the one that includes your test page. I see some JavaScript errors
when I click on the colored boxes on this page, but I’m not sure I
understand why they’re happening, or what is going on with this page.
Ok sorry about that. Try it again the file should be updated.
You can’t use Transition FX and Carousel Tab on the same element –
worse, acting on the same element. Take that off of both tabs. Also,
all three of your panes need to be exactly the same dimensions. After
I made those changes, the whole thing just worked.
Ok, do you know how to get this affect in freeway http://www.newleaf.com I
really like that affect with their carousel.
You could try using the Transition FX Action for this. I don’t see a
way that you could get precisely this look using Carousel. The best
you could do is to set the Carousel to vertical orientation, but then
you’re going to have a slightly different look – instead of the next
pane “wiping over” the stationary previous pane, the next pane will
“push” the previous pane out of the way as it moves in.
