I happened to view the Form on one of the client’s employee’s laptops (Win7) and I noticed placeholder text is not showing. Every other PC / Mac it’s viewing fine.
It’s IE 10 and up, if they’re using IE. Firefox and Chrome have supported this for quite a while. I have written a polyfill for the behavior, and you can add it to your page with two lines of JavaScript.
If you’re already using Prototype in your page, you can (and should) skip the first line. Put this in your page head, using Page / HTML Markup, in the Before slot.
