That sorts it as I use your HTML5 action in just about everything -
including my test file, so that explains a lot.
Works exactly as you say on inline div items
So then, the consensus of Freeway Pro experts is that Safari has a bug that
affects the fixed position behavior on the same page with either embedded
video elements or iframe elements?
On Mon, Jan 28, 2013 at 10:29 AM, Walter Lee Davis email@hiddenwrote:
Oh, I just looked, and yes that error is still in there. Your element must
be a DIV, set with the CSS checkbox or Layer checkbox checked. That error
is popped if the element isn’t found by line 325, which is looking
specifically for a DIV. If you are using my HTML5 Actions, you might be
trying to apply it to a section or article, and that could be the entire
problem.
On Jan 28, 2013, at 10:09 AM, Ernie Simpson wrote:
Sorry Walter, when I tried it it gave me an error containing this line of
code
fwError('Sorry! This Action must be applied to a layered HTML box');
On Mon, Jan 28, 2013 at 9:07 AM, Walter Lee Davis <email@hidden
wrote:
Just tested it here, and no, it does not require a layered element.
On Jan 27, 2013, at 6:16 PM, DeltaDave wrote:
Yes you are correct - Sticker requires CSS positioned layered elements
but it does the ‘only stick when at the top’ thing.
So then, the consensus of Freeway Pro experts is that Safari has a bug that affects the fixed position behavior on the same page with either embedded video elements or iframe elements?
Just revved the Action to allow non-div (HTML5) elements.
problem.
code
