Hi
I am starting to build a site that will have a fair bit of updated info regularly from the client; upcoming events page, blog, resources page, etc.
I am a bit intimidated by anything requiring code and am thinking that WebYep is the way to go for ease of use.
Any opinions, other suggestions, warnings?
If you’re looking for ease of use then probably WebYep is your best bet. Max’s actions, although I’ve never used them, seem to have gotten great reviews. Plus the cost is decent for what you’re going to be using it for.
If you need something more robust and big name then perhaps ExpressionEngine may be to your liking. It’s great once you understand how to use it properly, but there is a bit of a learning curve with it and it is somewhat pricey to buy. Joe Muscara’s actions are wonderful for it, however I do need to e-mail him to find out about how to load content from the Multiple Site Manager into the actions. But that’s for another time.
If you had any questions about WebYep I’m sure you could e-mail Max and maybe he’d answer them for you.
WebYep is cool and indeed had more options than it looks at first sight. When you think creatively and analytical you can get a lot of this little shiny cms
