when navigating between a website pages, for example you’re in domain.com and click on a link that navigates you to domain.com/products, a white screen will appear whole the webpage while page is loading. but in some websites like facebook, not all the page disappear, but just the content. and the header will stay there while loading. Is it possible to do this in freeway pro?
It depends a lot on the site, but you may just be seeing the effect of
efficient caching. If the server hosting the site is properly
configured, images and other static elements will be served with a
very long “time to live” setting. This allows your browser to maintain
a local cache copy of the image or other asset (like a stylesheet) and
rather than requesting it from the server each time it’s needed, it
can be pulled from the cache on your Mac, which is nearly
instantaneous. Careful use of Master Pages in Freeway will make this
happen for you pretty much automatically. Anything that is shared
among all of the pages in your site is a good candidate for being cut
off the instance page(s) and pasted onto the Master page(s). Likewise,
enable External Style Sheets in the Document Setup, as that will move
a bunch of redundant code out of each page and place it in one (easily
cached) external file.
If the site is designed to be a “single page application”, like Twitter.com. then there is actually something entirely different going
on. The outer page shell is loaded once, and then the inner parts are
loaded as fragments using a technique called Ajax loading. This is not
easy to set up in Freeway or indeed at all, since it requires a lot of
hard work to present browser-friendly URLs along with this fast-
loading partial page reload. It’s rocket surgery, to be sure.
