[Pro] White space between frames
I run a couple of frame based sites created way back using Freeway. I know I probably should reconstruct them without frames, but there’s over 300 pages and I haven’t got the time and energy at present.
Anyway, since migrating everything to Freeway Pro 5, I get a 2mm white line between each frame.
I can’t work out how to get rid of it. Any ideas?
Martin Coombs
If you set the Frame border to 0 instead of leaving it blank it will
get rid of that space (and also invalidate the page). You can do this
in the Frame section of the Inspector palette.
present.
Martin Coombs
Thanks very much.
Martin
