When I upload my website I have made or preview it in a browser the page width is wider than it is in the working freeway document, when in the browser a horizontal scroll bar is at the bottom of the page which allows you to scroll to a white space on the right hand side. every page is centred in the design but I’ve also tried having it aligned to the left but the problem still exists. just to be clear its fine in the working document I only have this problem when in a browser, also I have checked for invisible items and nothing is there all items fit within the page dimensions which is w=1080px and h=4000px
Thanks Dave,
this is my first freeway website, please could you advise me how to correct this problem, also the problem happens on every page even ones without image1.
I dont see your site at the address you posted before so I will have to make an assumption.
Is/are your pages based on a Master?
If so is the image container on the Master much wider than the containing image.
You can select the image container and use the Menu command Item>Fit Box to Content but without seeing your other pages I cant be more specific. It may be that you just need to make the image container narrower.
This is your main image - this means that the container is 1459px wide but the actual image is 1080. Reduce the size of the container (if this appears on the master do it there)
