Your issue is well known. Here’s the reason why it is so. Freeway is not an HTML editor, and unless you are in the Preview mode, is not using a Web browser to show you the page, but rather a desktop publishing application, similar to InDesign or QuarkXPress. When you are working in the layout view, and are moving things around on the page, you are not seeing HTML, but the internal document’s approximation of what HTML would look like. Since browsers and platforms don’t always agree on what that should look like, this is necessarily an approximation. If you click on the Preview tab, Freeway will generate the current page as HTML, and show it to you in a WebKit view, which is similar to Safari or Chrome, but is explicitly not either of those browsers. The hitch is that you cannot change or edit anything while you’re in that view.
It’s important to really internalize the fact that Web pages are flexible, unpredictable things, and you do not have the ultimate say in how they will look. Any number of user-controlled settings, or the platform (google Windows Typography – you will get “oxymoron” as the first result), or the computer’s settings (Big Fonts setting in Windows, or MobileSafari on iPhone enlarging text to be more readable) can all conspire to make your page look entirely different than you anticipated. For anyone coming from the security of print design, this can be an awful fall from grace; after all, your printed pages don’t get up and rearrange themselves if you view them in a different room, do they.
Knowing this fact, and not trying to fight it, you design to allow for things to grow and stretch and rearrange themselves, and you do so understanding that this is a flexible and fluid medium, not fixed like print. Get into the practice of looking at your sites on different devices, or adjusting the font size in your browser a couple of clicks in either direction, as a part of your regular proofing process. (Be sure to set the Zoom Text Only option on in your View menu before you do, or you will be lulled into a false sense of security.)
Getting a page to look exactly the same on all devices should not be your ultimate goal – that way lies madness. Getting your pages to be usable and useful on any device should be your measure of a job well done.
On Jun 10, 2014, at 12:19 PM, Iain Mackenzie wrote:
Why does text not appear the same in browsers as it does in FWP? Spacing and formatting seems to be different, and hence positioning is thrown out.
Graphic boxes are OK, so what is the problem with text?
If I could work out how to post images here, then I would attach screen grab examples.
