You will see the same effect if you look at your site with desktop Safari and enlarge the text - first use Safaris View Menu>and check the Zoom Text Only option.
Your page is constructed with layers that overlap if the text is too large.
Thanks David, I see what you mean about the desktop zoom function.
Does that mean I have to change the way I’m designing my pages if I want them to appear natural on an iPhone - the same way most other sites seem to appear correctly?
!!! we copied & pasted that from an external review site so was a customers spelling error. Are we allowed to alter stuff like that?
I need to research how to make a mobile version in freeway as I’ve never done one before. I guess time issues would come into, making another version of the same site, but something I can look into.
Is there anything in the meantime I can do to get the current site looking half decent?
Well, considering you might be bending copyright just by using that
content on your own site [wry grin] this seems like a very small
point! Personally, I would lean towards using the correct spelling.
The old site had a direct link to that page so I guess it wasn’t an issue then. I think I’ll live with the small point lol and get the spelling changed.
