Firefox seems to handle it better. For Safari 5.0.5, it sometimes flashes the image that has the Transition FX (first hidden then fade in) from time to time. Sometimes it doesn’t, sometimes it does. I tried my older Safari on my iMac G5 and it never does it on that one. Works perfectly there. Is it just the way Safari 5 is?
http://www.membersinunity.com/aboutmiu.html
Is your Entrepreneur graphic set to fade in?
It more appears to me that it hides the MTML text underneath and that because of the size of the graphic entre.png it doesn’t load quickly enough to obscure what is behind.
Try reducing the file size (229K) - changing it to a jpeg and increasing compression will help dramatically - and see if that makes a difference.
Will do. Thank you!
