I’m age 71 and not too high-tech. Fwy 6 Pro does everything I want it to do for my website. I’m reluctant to take on a new learning curve with 7 Pro.
My question: Hopefully I have 8-10 years left of health that will allow me to keep working on the website. Is there any likelihood that 6 Pro might become obsolete in that time frame? Or is it realistic for me to expect that 6 Pro will continue to do fine, assuming that I keep my computer hardware and OS up to date? I keep my website pretty basic.
(I realize I’m just asking for an educated guess.)
In 2021 we will just have to press a button and a website, a brochure or an ad will automatically be designed for you. Strangely enough, one of my main clients thinks this already happens.
Therein lies the issue - you may be able to change hardware and OSX only so far into the future before a (future) legacy program like FW6 no longer is compatible.
On the other hand, you CAN keep Macs running a very very long time. Somewhere around here I still have a Power Macintosh 8500 - mid/late 1990s machine and it still runs, as do it’s (mostly useless) retro programs!
As long as the way your ISP allows you to connect to the internet doesn’t change (it could too - remember dial up?) you may theoretically go forward with older equipment for quite some time.
FWIW - the new learning curve things in FW7 are mostly new features - and no one said you had to use them. You’ll find the rest very familiar.
In spring 2015 there will be a sitebuilder launched who actually designs
and builds a site for you, based on certain parameters. The future is
near…
Op 25 nov. 2014 11:27 schreef “Noel Sergeant” email@hidden:
If I were to upgrade to Fwy 7 Pro (from 6 Pro), would it be as simple as just opening my 6 Pro file in 7 Pro? Or would there be changes imposed by 7 Pro that would require my editing my 300+ pages (spacing, font management, etc.)? If 7 Pro would just seamlessly open 6 Pro without altering it, then I will probably take a run at it, then learn some of the new features as time permits. Thanks to all for the input.
Yes. Just open them in 7. FW makes a backup of your former 6-file in case
you may change your mind. Most of my files opened well in FW7. I had more
problems with 5.5>6.0.
But if you’re not intend to use those FW7 features, why upgrade?
Perhaps it’s better to wait for a real update (7.1) to be sure that first
problems and issues are eliminated?
2014-11-25 19:25 GMT+01:00 Jim Feeney email@hidden:
familiar.
Thanks, Andries (and others). And waiting for 7.1 seems to be the best option for me. The upside of being age 71 is having enough spare time to tinker with a few of the new options if I feel brave enough.
2014-11-25 19:50 GMT+01:00 Jim Feeney email@hidden:
