[Pro] with white lines appearing within the graphic background
Hi All
I have a problem with white lines appearing within the graphic background found here: http://www. bajanapple. com/aboutbajan appleg.html this appears in Firefox on the Mac and also Win XP SP3 when using IE 8 http://www. bajanapple .com/howtosend filesba.html
I tried changing things like, GIF to PNG, Layers, move to front or back but with no joy. Any suggestions?
On another note the logos found on the form pages move when they should not. This results in the logos appearing behind the graphic box and text as seen here: http://www. bajanapple. com/quotation request.html
The logos go even further down and behind the grey graphic box when viewed in Windows. It’s a problem in terms of how the site looks on these pages.
Any suggestions always appreciated.
Tony
Because you have constructed your page(s) with a Table layout then any browser inconsistencies in rendering text at different sizes can cause your layout to break apart.
If you look at your FW page and enable HTML Layout under the View menu you will see the different areas of your construction and the lines between them where this can occur.
Using layered items will stop this but to ensure that your layout will render at all Viewers text sizes an Inline Layout or use of the RPL action is recommended.
Have a read of this article http://www.softpress.com/kb/questions/201/+Graphics+shift+down+the+page+or+have+uneven+gaps+between+them+when+previewed
