I’m having a strange issue with Wow Slider and the Backdraft 1.5 navigational menus. If you hover over a Backdraft drop down menu while the Wow Slider is active the submenu text will get briefly lighter when each slide transition occurs. This will only last a few seconds, at which point the text will return to normal until the next slide transition.
This ONLY happens on pages that I’m using Wow Slider, so that definitely is the culprit. FWIW, I’m using Wow Slider 5.4 and inserting the code after the head.
Let me clarify my last post. Wow is touch sensitive, but what I meant was when you scroll your finger across on an iPad or iPhone there is no scroll response if you are swiping over a slider.
