Anybody used the WOW slider? Anybody got it to work in Freeway pro? I just spent an hour trying to get it to work with no joy. I would like to publish locally first then upload all the files using an FTP client.
Does anyone know of a way of getting it to work in Freeway? Please let me in!
Cheers!
Actually hold on just found this
http://www.freewaytalk.net/thread/view/85767#m_85772
Seems easy enough Ill give that a go
Hmm this isn’t working at all!
Are those instructions working for other people?
We would have to see your page code to suggest remedy. But just in case you missed this issue, WowSlider is JQUERY based so it cannot be used on the same page with Freeway effects based on Prototype/Scriptaculous.
Ensure that the Data and Engine folders are in the same folder on your web server as your page that has the slider.
Marcel
Hi Justin, I’ve played around with wowslider and the only issues is image quality, which requires a bit of fiddling.
Post your page so we can look at it.
Bryan
Just popped out, will be back shortly to upload, thanks guys
k - got it working if I upload to the server… still cant see it locally though - it just creates 4 little squares, with question marks in it -
http://easthalldesign.com/wow/
You cant see it locally because you are using relative paths to the JS in the head of your page.
Change that to absolute to the files on your server.
Ta
