[Pro] wowslider not showing on chrom
I have created a page with a wowslider in an iframe. It shows up fine when I launch it in Firefox. It disappears in google chrome. Probably cause? www.rangeleylakestrailscenter.com/blueflame (It should show up on the upper right corner of every page.)
I just checked your link in Safari, and I don’t see the slider. In fact, no
one but you will ever see it because the source code shows the iframe
source as being on your local hard drive - something the rest of the world
cannot see.
  iframe
src=“file:///Users/admin/Desktop/Blue%20Flame%20site%203/BFG%20Alt%202/index.html”
for me and the rest of the world to see the iframe contents, they first
must be uploaded with the rest of your website and correctly referenced
there. Because the file is an index file, that creates some limitations on
how you do that.
I’m hoping someone with wow slider or iframe experience jumps in here to
help out, but this is where you start to solve your problem. Good luck.
Apart from the issue Ernie raised the engine1 folders do no appear to be where the path in the code says they are supposed to be! that would be in the ‘blueflame’ directory so you need to upload that folder there along with the ‘data’ folder which wow normally also creates.
HTH
I have wow sliders in iFrames on various pages on this site.
http://www.richard-lowther.com/doucefrance2/
In the publish window of Wow slider use the “Publish to ftp option” having first placed a folder on your server to upload to, using Fetch or some other FTP app. Then, in the iFrame action, put in the full link to that folder.
Looking at the source you should find something like this
I am aware that there are those in the freeway community would recommend “insert to page” option but this is a quick method for me when working on development of a site and sliders, as on this site
Richard
Thanks for all the good input here. I’m no code person but I’ll work on
this and see if I can get it going.
Much appreciated.
Carol
On Mon, Jan 7, 2013 at 10:09 AM, Richard Lowther <email@hidden
folder.
Richard
