I feel these problems you are having might be cache, you will need to
clear it from the browser you are using. Sometimes your hosting
company will hold the cache on you but if you click the reload button
a couple of times in quick succession this might clear it… you could
also try highlighting the address and pressing the return key a couple
of times rapidly which also seems to help if the other option doesn’t.
HTH
On Jul 27, 2009, at 9:49 PM, andrea wrote:
on each page of my website, either the header graphics are missing
or placed incorrectly, eventho in my Freeway Pro file they are
correct. Any ideas?
I sent a rely ply to this which doesn’t seem to have come through, don’t think this is the list, fairly sure it is my ISP so sorry if it gets repeated…
I feel these problems you are having might be cache, you will need to clear it from the browser you are using. Sometimes your hosting company will hold the cache on you but if you click the reload button a couple of times in quick succession this might clear it… you could also try highlighting the address and pressing the return key a couple of times rapidly which also seems to help if the other option doesn’t.
