Which style is being overwritten?
Okay, the table page is now encoded with XHTML 1.0 Strict and everything works fine, save the blue bar at the bottom of the table. Not sure what to do here.
I could add another style to the HTML page markup, but is it possible to have two Extended Attributes named class in the same table row/cell?
BTW, I deleted the test page. Here’s the updated page:
http://www.williamsburgmemorialpark.com/properties/propertyoptions.html
No, but you can have two values, separated by a space.
<div class="foo bar">whatever</div>
The two styles will be merged if they are separate rules, and you can also create a double-class selector (or as many classnames as you like, up to some limit that causes IE to cry for its mommy) like this:
.foo.bar { color: red; }
That rule will only apply to elements that have BOTH classes applied to them.
Forgot to mention – to get this in Freeway, you would use the Extend(ed) button and enter this:
What is your problem with it
You can have 2 classes but they should have different names and as many attributes as you like.
Hey David,
I don’t have any problem with the blue bar at the bottom (the way it is), but I was told I’m not supposed to use empty table cells for decoration (i.e rules, etc.). Just trying to be a better website designer.
Two classes makes it easier, so perhaps I’ll try that.
