Keven,
Now that waltd has explained “text area”, I did some further testing
and wrote a php script on my server and sure enough FW “text Areas”
work. Now that you have updated your webpage, By doing a view source,
I see the problem. There is no “name” in the HTML for the Text Area on
your page. The line of code on your page is:
Type comments here.</
textarea>
. It should look like:
Type comments here.
. Go
into FW to your contact page where this text area is. Select the text
area so its inspector window shows up. Go to the third tool in the
toolbar of the inspector window, the one that looks like a little web
page. You should see the first field labeled Name. If this is blank,
according to my tests, this will produce what I’m seeing on your page,
i.e. no “name” in the HTML code. Check that this has some text in it,
i.e. the name of this form entry.
LLE
On Jul 29, 2008, at 11:55 AM, Keven wrote:
my website has been updated with the comment section back in, so if
anyone can tell me what is wrong with, thank you again
