Hi all, I am having this problem also. (similar, anyhow)
My page has several background images…a graduated screen box (that has an animated gif as a separate header)…and another box I am using over the background box (this box will visually contain my text, etc (I word it that way, because I am NOT importing anything into this box. I am JUST using it as a design element…just trying to save us from confusion!)
I grouped my rollover images, then used the rollover action. As soon as I group the images and add the rollover action, a red box outlines the rollover and I cannot move the rollover or duplicate it. (the duplicate command gives me an error message that this would “position my items off the pasteboard”…even if I duplicate just 1 item with 10-pixel offset.)
I must be doing something wrong, I know, but I have not been able to figure out what it is…I have looked through the Forums and read the manuals. I have watched Freeway moments…I wish there was an full online course for Freeway Pro…I would surely use it!
I suspect that my problem lies somewhere with the combine graphics/layers concepts. I think I am missing something about the proper way to structure a Freeway page.
My rollover consists of psd files which each are named differently and have type/shapes in different colors. I imported, stacked, grouped and applied the rollover.
Is it possible that I can’t use native psds this way?
Is there a simple step by step procedure to create and duplicate my rollovers, swapping out the different images for the separate menu items?
Thanks for any help you can give!
Helen
PS–Alex, I apologize if I have hijacked your thread…I just thought it would be good to keep these issues in one thread…I’ll be happy to start a new one if that’s an issue!
