I have a problem with the CSS menu in Freeway Pro 5.2.1
On the test page of the website: http://www.labadoux.be/historiek.html you can see the menu. It works fine on a Mac but not on PC.
The active buttens in the menu ‘nieuws’, ‘foto’s’ and ‘myspace’ are working and they can see the sub-menu’s but it isn’t possible to select those sub-menu’s (they disappear when the mouse goes down on the page).
Any idea what I’ve done wrong?
Thanks for your reply.
It’s hard for me to explain in English.
As an example: under the secund butten ‘Festival’ you have the submenu A.: programme with vrijdag, zaterdag and zondag. B. Historiek and C. Partners. All these items can’t be selected on PC.
Bart
P.S. In Dutch we use apostrophes after a word ending on a, e, i o or u
My apologies! I often forget how different a language Dutch really
is; it uses apostrophes to keep stressed (but unaccented) vowel
sounds long as well as to indicate omitted letters, and it doesn’t
distinguish between plural and possessive the way the English use of
apostrophes does.
I’ve found what causes the problems in Internet Explorer. In the masterpage, the color of the CSS-menu was set to ‘none’. I changed the color to ‘Black’ and now it seems to work.
