Problems with Internet Explorer
I recently up loaded my site, which works great in Safari, however it acts up in Internet Explorer. Please take a moment to see what happens.
http://web.mac.com/bldredge/BioFOAM_SITE/index.html
Any suggestions? Your will be very appreciated!
Thanks.
Hey, Ben –
You’re probably experiencing problems with Internet Explorer 6. I had the same problems a few days ago.
Softpress is working to fix the problem, but I suspect it might take some time given that they’ve just launched Freeway 5 and are busy on that.
The solution I arrived at was to put a box on my home page that says, “This site runs best on Safari, Firefox and Internet Explorer 7. If you’re using Internet Explorer 6, you can download the latest version by clicking here.”
If you’d like to see the site, you can visit it:
By the way, are you using a third party for your streaming video? If so, what company are you using? It looks great.
– Jamie
Thank you. Now that I am aware of the problem, I guess I’ll have to respect that there is nothing I can do to fix it using freeway.
I wonder if I could cut and paste code into dreamweaver some how and use it to export the site. . . Not that I know anything about code. . .
And as for the video-- actually I used an iFrame linked to a different page. Each video is on a separate page within that iFrame.
Hi Benjamin,
Could you send us your file so we can take a closer look please. the
address to use is support @ softpress.com (without the spaces).
Many thanks,
Joe Billings
Support Technician
Softpress Systems Ltd
code. . .
List Options | FreewayTalk
