I upgraded to Freeway Pro 5.3.1 from the previous version.
New tables allow Layers under Properties. All existing tables do not show the Layers options.
Also, when I try to create an HTML item with another HTML item, Freeway crashes. If I try to copy and paste an existing table or html item from one page to another, Freeway either crashes or the item will not paste.
Can you send the crash report (and a file with repeatable steps if you
can) to us at support please <support(a)softpress.com>. Crash reports
can be found in the shortUserName/Library/Logs/Crash Reporter folder.
Many thanks,
