Hi! Last week I changed my macbook pro with a new one, which works with Maverik.
When I opened Freeway I found some problems (it quits very often, the browser preview doesn’t work etc.)
Anyone who had the same problems and could help?
Thanks a lot!
Andrea - Italy
Hi Andrea
What version of Freeway are you using?
Tony
Hi Tony!
I am using Freeway Pro 6.1.2. To be sure, I downloaded and installed it again. But it still does not work properly.
Andrea
You would be best to contact support(a)softpress.com - they may want to see a crash log if you have one.
Ok. thanx!Andrea
