Start by trying to type into the Markup dialog.
If that works, try copying and pasting a small and simple bit of text.
If that works, try copying and pasting the first part of your code.
Etc.
Do you still have problems? If so, where do they appear?
hi, and thanks for your quick answer.
problems keep on remaining…
i tried to copy only the first two lines of the code.
when i go to paste markup, the wheel starts rotating and doesn’t stop itself.
i don’t know why.
if i try to type into the markup dialog box, when i view the preview, appears only the text.
instead of this, i wanna insert in my pages an image that links my guests to my tripadvisor’s page.
hope to be understood.
When you do this a new window will open - paste your code into that,
click OK, and you’ll have a new 100x100 pixel box on your page.
The markup code won’t show anything while you’re in the design view,
so preview to see it working.
Back in the design view, drag this wherever it should go. Resize it
so it is 160 pixels wide by 110 pixels tall and you’re done.
(160x110 is the size of the thing that Tripadvisor will insert into
your page INCLUDING the 10px padding in from the top and left that
this gets. Weird, but if you size your box to 160x110 you’ll be able
to use it in your design fairly easily even though you only see the
results when previewing.)
