Problems with Target Show/Hide layer
Hi all,
I’ve a problem with the Target Show/Hide layer and the sequence layer actions. I’m doing a fade style slideshow and it works fine in Safari but not in Firefox. Javascript is on.
Now here’s the biggest issue. A similar slideshow with exactly the same options on a different page works fine.
Any ideas?
Since you’re using Firefox, please do install Firebug http://getfirebug.com
and see what (if any) errors are produced on the broken page. Or
post a link to each page here, and we can look. Some browsers are more
“strict” than others, and an error in one might be silently corrected
by another. The ideal of course is to work everywhere, but the devil
is in the details.
On Jun 11, 2010, at 6:20 AM, Graeme wrote:
Hi all,
Any ideas?
The other thing to look for is if there are any other actions on the non working page that might be causing a conflict. Especially ones that use other javascript libraries - like Moo.
As Walter suggests - post a link to the online version of the non working page.
Hi Guys,
Here’s the link.
http://www.admindesign.co.uk/tc04/
You’ll notice that it works fine in Safari but not Firefox.
Let us know your expert opinions.
Graeme
This may be to do with you having Script/Protaculous and JQuery on the same page.
Javascript libraries are known to clash.
That doesn’t seem to be the case here.
the same page.
Firebug said this
Failed to load source for: http://www.admindesign.co.uk/tc04/
But I have no clue exactly what that means other than maybe it cannot find a particular script? But why Safari can and FF can’t…
Also got this with IE 8
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; WOW64; Trident/4.0; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30729)
Timestamp: Mon, 14 Jun 2010 19:15:19 UTC
Message: Permission denied
Line: 162
Char: 4
Code: 0
URI: http://www.admindesign.co.uk/tc04/
The Target Show/Hide stuff all has support for frames, so you might want to fiddle with those settings. Permission denied sounds like you might be violating the Same Origin Policy in JavaScript. Is your site in a frameset, like maybe your ISP does “domain cloaking” or similar?
Thanks for all of this. However, I’m still no further on to this, and I’m afraid I’m not clever enough to know how to fiddle with frame settings. As far as I’m aware I’m not using frames, but then again I’m not using much if my brain either. Look at another page on the site.
http://www.admindesign.co.uk/tc04/mortgages.html
This works fine, and it’s exactly the same settings apart from the file names, etc., which seems strange.
Graeme
Your site is not in a frameset, but your code is asking about frames in nearly every call in the Sequence Timer. Try changing the Find Targets picker in the Actions Palette from ‘top’ to ‘self’ and see if that clears it up for you.
I seem to have found the problem. I had a feedzilla news thing in some HTML markup. By taking this out, the slideshow works. Seems to be some conflict.
The client wants a news section though. Any other options?
Thanks for all your help.
Graeme
The ReadFeed Action can read an RSS feed from another site and format it into HTML. That’s done in pure PHP, no JavaScript involved, so it can’t conflict.
Okay. So how can it be explained?
Graeme
I’ve put in a different news feeder and all looks fine.
Feedzilla is not the same thing as ReadFeed. I believe Feedzilla is done in JavaScript, which would have a strong chance of conflicting with Target Show/Hide.
