Problems with The Church of Mac
Hi everyone!
Please help a newbie here. I switched from Golive 9 to Freeway Pro. I’m enjoying it a lot (blogged about it here).
http://imyourgenius.tumblr.com/post/32724799
But, something is going on that I just can’t figure out. In Freeway, these pages load perfectly. When I preview in Safari, they are perfect. But after I upload them, they come up with missing graphics:
http://www.thechurchofmac.com
I don’t have much experience in webdev, so it just could be me. Could someone take a look and give me some ideas?
Tony, aka, Dr. Bobby
They look fine on the uploaded version of Safari 3.1.1 and Firefox 2.0.0.14 , Netscape 7.0 even IE 5.2.3 which was the last upgrade for mac.
You might make sure you have the most up to date version of Safari 3.1.1. You might hit the “empty cache” button in the Safari file menu.
I myself don’t like Safari because of the bad luck I have had with it. Safari 3.1.1 seems to fix alot of the old bugs
If you mean the missing navigation graphics it is because the page code is:
Resources/podcastbtn.jpeg
but the actual file is at
Resources/podcastbtn.jpg
Have you been manually uploading?
If you also change HTML code: to more readable in the output section of File>document setup we will be able to go through your code easier to see any problems you may have.
