Clean up the Alt text on those and the site will validate.
The problem with the images slicing/breaking apart is because you have
HTML text over graphic items. Freeway slices up the graphics and
places them and the HTML text into a table structure, the HTML text
will inevitably grow on some browsers so pushes the table cells apart.
It seems that a lot of your problems could be fixed by combining
graphics and grouping elements together to force a better table
structure. It’s difficult to say what items would need to be grouped
without seeing the Freeway file though to be honest so you may need to
use a bit of trial and error.
You could also try setting the background of some of the items to the
color of the surrounding areas, such as the picture above the text
“The Hag is back!” and the image of the filmstrip.
I hope this helps.
On 6 Sep 2008, at 16:28, Fergus T wrote:
Hi… One of my websites have a few problems. It was built with
Freeway Express 4. Here are the problems:
