I don’t have any real documentation yet for the Protaculous stuff.
There is a rudimentary tutorial at the home page: <http://
Carousel in Freeway>
At this point, the actions in Protaculous fall into two categories:
###Geek-friendly
Protaculous: Page-action that attaches the library of your choice to
the page, then allows you to observe the DOM load and Page load
events and add your own hand-written code into those events.
Observer: Item-action that attaches the library of your choice to the
page, then allows you to observe the Click, Double-click, Mouseover,
or Mouseout events on any drawn element on the page, applying your
###Designer-friendly
Carousel: Item-action that creates a smooth-scrolling animation
switching between multiple “panes” of information.
Carousel Button: Item-action that creates a forward/back control to
drive the Carousel. Requires that Carousel is applied correctly to a
stack of DIVs, and that same stack is grouped with the control.
Carousel Tab: Item-action that creates a direct navigation control to
drive the Carousel to a particular pane. Same caveats as above.
Older versions of Protaculous included a SmoothScroll Action, but I
have removed that because it had problems that I could not resolve in
creaky/evil windows browsers.
On Apr 2, 2008, at 9:28 AM, Jamie Turner wrote:
Hi, Gang –
I’m starting to explore some of the Scriptaculous and Protaculous
actions.
Is there any documentation available for them? I know the new FW5
User Guide has a little bit of information on some of the
Scriptaculous actions, but I don’t know where to find more complete
information.
Suggestions?
– Jamie Turner
dynamo mailing list
dynamo mailing list
