I wrote Protaculous when I started getting seriously into Prototype/
Scriptaculous work a couple years ago. Basically, it’s a way to get
you started adding rich interaction to your Freeway pages. It uploads
the two libraries and links them to your page, it provides a couple of
canned “listener” functions to attach your own code to the page, and
that’s it.
Protaculous (the Action bundle) also includes the Observer Action and
the Carousel Actions.
Observer is just like Protaculous, except it is an item-action. That
is, you apply it to an item on your page rather than to the page
itself. Using Observer, you attach an event listener to a particular
page element, and then when that event fires, the script you’ve put
inside Observer is called forth to do something.
Carousel probably doesn’t belong in this Action at all, it’s gone on
to have a life of its own, and I’ll probably carve it out into its own
stand-alone Action some day. I won’t go into detail about it, you
should read the documentation and try the example on ActionsForge.
So Protaculous and Observer are geek-level tools, useful primarily if
you can write your own code or find an example on the Web somewhere
and figure out how to use it. They provide the launching pad for
taking hand-coded JavaScript into Freeway and making it dance and sing.
On Feb 4, 2011, at 1:36 PM, Rice Martin wrote:
I was afraid I might be hijacking the thread to I started a new one.
I followed Walter’s instructions for getting this working and it
worked like a charm. I’m very pleased.
I didn’t have Protaculous so I downloaded it and installed it before
I started.
Now I’m wondering what Protaculous is really for and where and for
what else I’d use it for?
Any explanations would really be appreciated by the new user of FWPro.
Martin
Signal Mountain, TN
