Publish Problem window
I’ve completed my website using Freeway Pro 5. When I go to check my pages in the browser a Publish Problem window opens saying one of my actions has been incorrectly applied and will be ignored: Action: “E-Buy Form” I never applied that action to the page. The action I did apply was a PDF file. I cannot find E-Buy action anywhere on the page to delete it.
also
Overflowed Text message: The following items contain overflow text that will not be published. Again, I cannot find any overflow text on the page that is identified.
When I check my pages in the browser everything works fine.
Will these things prevent me from uploading and publishing my site?
I’m at a mystery as to how to correct these items.
Your comments and suggestions would be greatly appreciated.
jerry
OM Publishing
In your “View” window do you have “Action Names” selected. If not, then when you do a little action name in a yellow-ish box will show in the upper-left corner of any item that has an action applied to it. If it is on, then switch to item view (using the COG at the bottom of the site panel (left side) and select “show items” and search through your layered items (or tabled items) and look for any of them that have the Freeway icon in the icon to the left of the name. That means that object has an action applied to it.
That’s 2 ways to find it.
As far as the overflowed text items, it usually gives a specific name. By switching to item view you’ll see all the names of the layers (or tabled items) find it that way and then adjust it.
See if that works.
Thanks Dan,
I’m aware of the Action icons and where they are located. In the site panel on the page in question, I cannot find anything that is not supposed to be there.
As for as the “overflow text”, when I go to the graphic box where I have inserted text I cannot find anything out of order. Like I said everything looks fine and functions properly in the browser.
jerry
Are you sure that your Master / Published page is still established (as far as the action problem)?
Perhaps try to drag down the graphic “text-box” a few pixels or so and see if it still gives you the error.
