I have managed to include the e-buy text action to a page by mistake. I get a publish problem notice when I try to view the site in a browser. It tells me that the action cannot be used because it has been incorrectly applied. I’d like to lose the action, but I can’t find where it exists in the page. How might I go about deleting this action and thereby eliminate the constant warnings.
I think? all you have to do is open your “Actions” window, then click around on each item on your page keeping an eye on that Actions window - the one that has the E-buy Text will identify itself as such on the Actions window - you can then simply cut/backspace to get rid of it, then recompose what you lost (if anything) in a new element on the page…hope that helps!
